Cigarette Lighter Socket
6K views 14 replies 10 participants last post by  48365
Is it just me or is the rover cigarette lighter socket in the 200 bubble rubbish to plug in something like a car phone charger, i have to hold it in to get a good connection and if I dont it looks like it will fall out if i go round a corner or over a bump. How can I improve this?
Cheers Harry
If you dont mind a bit of work, and a bit of chopping, you could always cut the adaptor off he end of the charger, fit and in-line fuse to the positive cable, and then splice the cables with the ciggy lighter cables.
That way the charger cable which plugs into the phone will always be in the car when you need it, and if your not using it, you can tuck it behind the dash.
Its not everybody's cup of tea, but its what I would do.
Would this work with an ipod docking station?
Ill outline my idea...
the docking station has the option for the usb cable into back so could wire this into ciggy lighter so when i plug ipod into docking station in car it will charge??!
Dock at the minute just uses standard 3.5mm jack to RCA connectors so no power goes to dock.
Im thinking of modding the area around ciggy lighter to permanently install dock (at the moment its just sat infront of gear stick), any ideas?
The cable is ran through the back of ashtray and to head unit.
Any ideas or if anyone has done this would be great...photos even better ;)
