Check Engine! warning light
3K views 7 replies 4 participants last post by  MikeM
Hi,
Just before xmas while driving my R75 the Check Engine! light flicked on.
The car drives normaly and seems not to be affected in any way. The warning light seems to have a life of its own, after a couple of days it will go away, then flick back on at a random point in time while using the car. My local dealer has looked at it under warranty and replaced an accutator in the inlet manifold and reset the ECU..
The warning light has started comming on again, I can't figure it out, perfomance seems normal, the only thing i can figure out is the light comes on under acceleration, any type of acceleration whether it is hard or gentle.
The car is going back to the dealer again. I just wondered if anyone has come accross this type of problem before?
Salop75
Hmmmm ok I know it stating the obvious but it would definately seem to do it when the engine is underload. It may well me another sensor/actuator that is faulty. Does it do it under any particular cambers? Does the weather effect it ie the wet?
It can only be very intermittant and certainly not anything major or else the ECM would flag up a diagnostic code for the engineers to read. I am certainly not familiar with sytems used by MGR so I cant help thats much :(
I would put my bet on it being a faulty sensor. How old is the car?
Hi Vitesse,
I agree it would seem to be related to the engine being under load, but i'm not sure what kind of load. One evening I had to accelerate away from a roundabout and had the gearbox(auto) in sport mode, with heavy acceleration :) the needle rapidly hit the red line before the gearbox changed up, no warning light - 5 min's down the road cruising at 30mph along some country roads the light flicked on under very gentle acceleration with the gearbox no longer in sport mode.
I wondered if the 75's had the little led flashing panel under the passenger footwell carpet like older model rovers, that tell you the ECU status?
The car is 2 1/2 years old, 33k miles on it, the MIL only started to come on over xmas, maybe the cold/wet weather has something to do with it.
Salop75
#4 ·
Salop75 said:
Hi Vitesse,
Salop75
Errr yes "older" not "old Man" lets state :rolleyes::lol:
Yes you are correct, the old honda powered 800's had the LED panel but they are long gone! Im afraid unless you have a hand held diagnostic unit or laptop, nobody will be going near your car!
Sometimes sensors can fail after a year old and your millage but its not common, but at least its still under warrenty :)
I would just incist that if they cannot find anything with the car stationary, that they take the car for a run and just state to them when it does it. I would seem that it effects only partial throttle, so maybe another sensor in the induction system...... a throttle position switch or mass airflow sensor. I don't know what Rover engines have fitted to them and I am purely having a guess here :p
