1 - 11 of 11 Posts
rover_45
Okay so I hear many peeps go on about the ticking sound coming from the plenum valve but where should the pipe in the picture attach to at the loose end OR should it just dangle freely?
That goes into the cross member below the bulkhead. You should see a plastic insert in the member that the pipe plugs in to. Just look behind the gearbox.
mine is clipped to another pipe at the side of it...high up
the other open end, just dangles the other side of the steering rack gator
no pics as you can only feel on mine as it's the 420
all the best..mark
1 - 11 of 11 Posts
