1 - 20 of 20 Posts
Hi all
Is there a proper way to get all of the engine oil out? when I remove the oil filter oil seems to comes out every little, (1/2 Litre) and when checking the dipstick it still near to full. Is there way to get all the oil out or am doing something wrong? I own a rover 200 vi (98).
thanks all
evian said:
thank you for replying, the sump screw/plug you mentioned at the front bottom of the oil tank seems to be very hard to take out! is there a way to take out easier?
thanks again
Use a long socket wrench or breaker bar.
When you put the sump bolt back in use a new washer.
when you put the oil filter back on smear a thin coating of new oil onto the rubber seal and tighten so it's tight by hand and no more.
I thought id make sure you know when putting a new washer on the sump plug make sure its a proper sump plug washer. Theyre normally made of copper or sometimes aluminium. They are designed to crush down slightly to give an oil-tight seal and prevents it leaking.
I'm gonna put my car in for an MOT soon and thought that oil could do with an change. How much would be the expected cost for a garage to change the oil and the filter? and possibly the fuel filter... (i have a new oil filter in the boot.. bought with good intentions to fit myself.. but never got round to doing it what with all the other bits and pieces i have had to do on the car so far)
Oh and i have a S reg 214i if it makes a difference.. been a while since the last service...
I like doing my own oil changes as i know that the correct grade of oil and quality has gone into the car (10w/40 for the K series engine)
you can do an oil change yourself - and the tools wont cost you anymore than what the garage will charge you to do it once.
This is a real saving in multi car households
presuming that nothing goes wrong, its not been unheard of for a sump plug to die (i.e strip).
although very uncommon, sometimes oil filters can be absloute pigs to get off, admitedly this is not a problem if someone who knew what they were doing last changed the filter.
if the oil filter is on solid - or the sump nut is tricky to remove the car should be going into the garage for a full service as it obviously hasnt had one in a while.
I have seen many a mangled sump nut for two reasons -
1 - it should be replaced on a regular basis but never is
2 - people use cheap/old/wrong size sockets on them and round them off
last time i bought a sump nut from rover it cost me around £4 - hardly going to break the bank - but can save alot of hassle next time around.
1 - 20 of 20 Posts
