pulling away from standstll yesterday (with a little bit of welly) and when I tried to change to second it wasn't there. None of the other gears were. And the gear stick movement was being restricted somehow. So I limped the rest of the way across London Bridge and pulled over (burning oil smell in the cabin)
Upon inspection it seems there's a hole in the bottom of the gearbox and all the gearbox oil had come out. I'm assuming the gearbox has destroyed itself and fired out through the casing. Is this 'normal'? And more importantly - how much is this going to cost to fix?
