1 - 10 of 10 Posts
As my previose strings have shown I may or may not have HGF or reading other strings just sludge in me pipes. The final test is a pressure and sniff test but what is it and what do they do
A sniff test shows if there are any traces of gasses in the coolant that shouldn't be there posibly indicating HGF.
A pressure tests shows up any leaks, indicating the same thing, and if there are any leaks in general.
In the Garage
MG TF
The pressure test will pressurise the coolant system without the engine running, this see if there is a leak.
The sniff test checks for combustion gases coming out of the coolant with the engine running.
Dam James C's fast fingers.
Okay if I get it , a pressure test can be done by a meter on the cylinders by removing the spark plugs and a halfords hand held tester Or according to strings ,bubbles in the coolant resevoir when cold as the gas escapes from the pots. I had a Nissan which would build pressure and release through the leak witha sound like air brakes.
The sniff test done by a hot wire detector in the water bottle which would detect the solvents in the petrol.
I am going to get a garage to do a test but keen to understand what they do
Think the coolant pressure test involves pressurising the coolant, then locking it off and watching for any drop in pressure indicating a leak.
A compression test done with the plugs out is something quite different.
AFAIK a cylinder pressure test and a coolant one are two different things.
A compression test (plug removal) would not always show a possible HGF, more so in the more common failure of the gasket betwen the oil and coolant ways.
A simple sniff test using an exhaust emissions MOT tester in the top on the coolant tank would detect the presence of hyrocarbons giving a much better idea if the HG has failed.
1 - 10 of 10 Posts
