Ok, so I have neglected the TF a little recently and hadnt noticed one of the fron brake pads was very low. it is now metal on metal (although still stops very well)
The car is a TF 135 with 15 or 16" wheels. not quite sure at the moment.
As the front disks are going to need replacing, what options do I have.
I dont want to spend too much on them if I can help it.
Also, why has only the drivers side pad worn down to the metal and the passanger still has at least 5mm? there is a slight pull to the left under braking.
