Hi,
If anybody could help me with some advice on the following it would be much appreciated.
I purchased a TF as a project a few weeks ago now and I am trying to get it road worthy. The car doesn't seem too bad but the brakes were awful and like a previous TF I had purchased I soon discovered that one of the front callipers had seized.
However, since I planned on keeping this car for a while I decided to purchase the AP 2-pot callipers with the bigger discs, which I was told was a straight forward conversion, and fit these.
It seemed straight forward enough, apart from the wheels, which I will get to in another post. 16 inch wheels with those brakes just doesn't work
Anyway, after fitting the brakes etc and driving the car to a local garage for some bodywork I soon discovered the brakes stopped working. That was a scary moment. I didn't die, but after some investigation by the garage it was discovered that the rear rotating side of the wheel hub had worn through the brake hose causing the brake fluid to spill everywhere, hence the lack of brakes.
The mechanic has since said to get bigger wheels because 16inch wheels won't work. He also said that I need different brake hoses because the current set up causes them to rub against the hub. Is this because I have fitted AP callipers? And if so, what hoses do I require? Any help is greatly appreciated.
My wheel dilemma will be in a separate post if you fancy contributing to that
