1 - 5 of 5 Posts
the boot light in my mgzr is not working the bulb is ok but i have no power to it can anyone tell me were the fuse is also were is the switch that operates it
thanks
mg_zs
If there is no power arriving at the bulb then it is a fuse or wiring fault. If there is power, te bulb is OK abut does not come on then the switch in the latch or the wiring leading to it is at fault. The switch in the latch provides a ground to turn on the light. Have a look at the latch, the switch is a blade which wipes on a brass boss fitted to the latch claw.
rover_45
Check the wiring loom that goes to the hatch through the body shell. Peel back the rubber and you may find that the wiring has split or is touching the bodywork.
Open ur boot and take the plastic cover off the latch.. U'll see a flap of metal that will be touching the latch mechanism.. This completes the circuit and turns the light on.. That's the switch.. If it's not touching or, quite common, the strip of metal has broken off, then that's ur prob..
thanks for all your advice in fact it was the metal strip in the latch
thanks once again to everyone who replied
cheers
1 - 5 of 5 Posts
