1 - 20 of 22 Posts
rover_75
My 75 1.8 classic SE has front fog lights, but I'm sure I read a spec somewhere that says it shouldn't. However I can't switch them on anyway, all I get is the back ones when I press the button to the side of headlights dial. So either I just can't find the button, or they're there for effect only.
Another daft question. My seat belt cuts into my neck, I've tried adjusting the seat but then I can't reach the clutch pedal. Any suggestions? Oh, maybe a cushion would work, I'll try that.
Ok, I think that's me for now.
mg_zt_t
If you've got front fogs, the switch should be to the left of the rear switch. On another slant though, and someone should back me up, if you have lights fitted to your vehicle and they are non-functioning that is theoretically an MOT failure.
Cushion OK as long as it matches the interior trim.
Luke.
Front fog lamps are not an "motable" item so as far as I'm aware "dummy lights" shouldn't be a reason for a failure.
As for the cushion, colour coding is of paramount importance. However I think the shoulder buckle is height adjustable.
rover_75
How strange, I def only have the one button. They must be there for effect. Has anyone else noticed this?
I shall seek out a charcoal cushion with immediate effect.
mg_6_gt
this is a daft question and in no way meant as a insult or cheek, but ar eyou sure there fog lamps ? jsut a few people on here have confused the front indicators for fog lights , just a thought ,,,,, where are they on your bumper
Good thinking Batman
Have you posted a pic of your car Anna? From that all will be revealed.
MM
rover_75
Discussion Starter · #15 ·
kandyman said:
OMG i missed a laff here :D
Not to worry if you dont ask you dont know
I was waiting for you to pop up!
I'll be watching for your next gaff...........:guns4:
:happy:
xxxx
pop up, now don't be rude :=p:
And as i'm not a blonde i wont be making a gaff.
But if i did have hair i'm sure it'll be blonde :O
rover_75
Discussion Starter · #17 ·
You mean you're a right said fred lookielike?
"When I turn the key in the ignition, my engine doesn't start, do I have an engine?"
Love it! :lol:
You haven't been the first nor will you be the last to do so, Anna! :)
Hi,
my 75 was delivered with factory fitted front fog lamps and without a switch for them. Although I was not able to order them, because there was no such option for a CDT with Automatic at that time. :wtf: Strange, isn't it?
Regards
Juergen
Correct, as the lamps were deemed to obstruct the airflow to the engine and gearbox fluid radiators.
MGR relented on this stipulation sometime later on, allowing front foglamps to be fitted.
I was asked the same question last Sunday at Beaulieu concerning another auto 75
1 - 20 of 22 Posts
