Hi
my mgf which I bought earlier in the year as a restoration project has hit aproblem..
I bought it knowing it had a failed head gasket, which i replaced and did cambelt and water pump at the same time all went well and i started it up ...
water after a few min boiled in the reservoir and after a bit of fiddling thought it might be a air lock as the radiator was not getting any warm water... stripped the radiator out to fliush it through and found it clear.. put the hose pipe in the lower pipe and water went through and into the reservoir....BUT when i put it in the other pipe the one on the left as you stand at the front looking at the radiator coming off the top... it seems blocked... so took the flexi pipe of in the engine bay where it comes from under the car and flushed it through.. thats clear but when i put the hose on the metal pipe which bends around the back of the engine under the inlet manifold ..... nothing water will not go through it..... im not sure now what to do have i got to strip all the inlet manifold of to get to where this pipe goes or is there anything else i can try....
many thanks in advance
Tim
Tim
