1 - 9 of 9 Posts
rover_75
Rite
I have a Wreg 75 so that means black sills and I had them painted when I brought the car but on the passengers side under the front wing the paint is starting to peal.
What I wanted to know will the black plastic coating peel off?
If I got a heat gun do you think this will work?
Its pained 100% under the seal but not too sure how far down?
Also
I read on here a while ago about these new washers that stop the noises from the rear shocks? What should I ask if I were going to order these from a dealer?
I sat in the back of my car for the first time while driving and I can hear some sort of noise
MikeM?
Thax
Alex
:=p:
It may be a rear bush and not the shocks Alex. I had one changed about a couple of years back - it's a BMW part - I can try and dig out the invoice to get the part number and from there you should be able to locate the one I am referring to.
rover_75
But it’s like a knocking sound and comes 100% from both sides! You could only hear it on the rough tarmac roads from the new forest trip.
And when I was driving I could not hear it, but when I was in the back the person next to me could not hear it at all. So who knows....?
Check the mounting bush on the rear arm. That was the one that failed on mine. It was in pretty bad shape actually, lord knows why, I can only guess the material was inferior.
rover_75
Discussion Starter · #8 ·
To think about it someone did say that they could hear a metal clunking noise when i had the windows undone,
Will have a good look see what i can see...
Rear anti rollbar links????
1 - 9 of 9 Posts
