1 - 20 of 22 Posts
on saturday my car has been really weird on me. i need your help to suggest what it could be!
i will explain below, exactly what the problem is:
1) of all, sounds like my induction kit doesnt work anymore.
2) my exhaust system doesnt sound half as loud, it doesnt sound as deep or as loud!.
3) response is slower!
4) engine sounds as if its straining, more engine noise than exhaust noise!!??
what could be the problem!???????
please help.
Have you taken off the induction kit and temporarily fitted standard airbox assy and noticed any difference ?
Lates
mg_maestro
Sounds like the engine has fallen out.
Good. You wont sound like such a chav when you drive flat out past a bus shelter full of 14 year old girls
Could be early signs of arthritis in your right foot?
Could be constipated, try Fibogel to get things moving again.
Discussion Starter · #11 ·
i will have to check it out tomorrow or something, i am very worried though.
the car runs ok but not as quick at all and sounds crap! no exhaust sound really or induction kit!
i dont know what has happened.
thanks for the posts lads.
keep em coming in if you have anymore ideas!
Does it rev freely in neutral, but seem really lethargic when in gear?
If so, check the CAT hasn't collapsed.
Discussion Starter · #13 ·
yeah when in idle it feels like revs take ages to come back down, kinda sticks high for a bit!
also it doesnt feel very powerful and sounds really tinnie!?
just dont sound correct! :sad3:
you think it could be the cat collapsed then?
Discussion Starter · #14 ·
took my motor to a garage today and got the cat checked out and it hasnt collapsed.
mechanic thinks it could be a sensor???
right or wrong?
Could be sticking throttle body, as said before: Take induction kit off and check that the butterfly valve inside the TB moves feely and opens fully!!
Discussion Starter · #16 ·
my dad did take off the induction kit air filter earlier on saturday but he put it back on to what i thought looked ok!
maybe hes moved something wrongly by mistake?
Didn't really want to suggest this.
Has the cambelt been done recently. If it has, I suspect the timing was done wrong, 1 tooth out on the cam.
If not it might be worth checking the timing anyway. My partners car (was a metro at the time) had the same symptoms and the cambelt had jumped one tooth. Needless to say we thought it pertinant to replace the belt
Discussion Starter · #19 ·
no it isnt the cambelt. had it looked at already.
last night went for a big drive to milton keyenes, now whilst i was driving there it wasnt running right and then it did. on the way back home it was loud again and running fine.
the only thing i remember was, i absoloutly filled my car up more with fuel than it could handle right, then it started after that. i never put more than 20 quid in a time, this time i put in 30 quid!
could this have made any difference? or affected something?
i am going to test it today and take it out for a bit and see if the probs persist.
my dad said hes going to check the butterfly valve and check if its opening fully... what would it catch on if it wasnt opening fully? or does it cjust clam up sometimes?
or could it be blockage in the exhaust? or is that idea rubbish?
help if u can, i appreciate it! thank you! please keep help posts coming in.
I think it is just your imagination, more fuel will make the car heavier that is all, or it could have been crap quality fuel.
If you are in any doubts take it to a garage as it is almost impossible to diagnose a fault over the internet.
Steve
1 - 20 of 22 Posts
