1 - 2 of 2 Posts
rover_sd1
Good day to all. I wish to replace the belt tensioner on my Streetwise 2004 TDI . I cannot see an easy solution except to remove the entire assembly from the engine block. This means removing the water pump, Alternator, and loosing the AC gas. The space between the tensioner and bodywork is just on a 15mm spanner's width. I hope someone can suggest a easy solution.
1 - 2 of 2 Posts
