1 - 9 of 9 Posts
mg_zr
Which one will my car have? It's a 1999 V-Reg 200 1.4.
If I do the head gasket then I will be fitting a new one when putting the cambelt back on.
Mmmm....Rover..
It should be an automatic tensioner given that it is a '99 car.
To be sure, if you PM me with your engine number I can check.
Any motor factors will be able to give you the right part from your registration no.
It will be the auto tensioner most likely.
Most likely yes, but definitely cant be sure as mine isnt! Mines a 2000 X Reg.
Technozen I want to check this with you where do I locate the engine number?
Is this the VIN?
Easiest way to tell is to ease the top belt cover to one side & look at it. If the tensioner has a 10mm headed bolt it's an auto type, the manual has an 8mm allen bolt.
mg_zr
Yes, what would the engine number be?
Say I had the manual tensioner fitted could I fit an automatic one and I also believe the belts are slightly different? I only ask as the automatic one seems easy to setup/align.
If I get back from work early enough tomorrow I will whip the top cover off and take a pic.
Mmmm....Rover..
The engine number is stamped on the right hand front of the engine block, it should also be present on your registration documentation.
It will be in a format similar to this...
14K4FL36 277643.
You cannot fit an automatic tensioner to an engine that was originally fitted with a manual item or vice versa, and the belts are also different.
mg_zr
Discussion Starter · #8 ·
Well, thanks to Technozen it appears my car has the automatic tensioner fitted, though what baffles me a bit is why S8an's 2000 X-Reg has a manual one fitted when it's a slightly newer car???
My have had some sort of head failure and it was swapped for a manual tensioner head.
It should be automatic. From '98 they were all auto as far as I know.
1 - 9 of 9 Posts
