Auto box oil
1239 Views 7 Replies 7 Participants Last post by  Billko
Hello there i have just bought a 75 tourer 2 ltr diesel auto, i have changed the auto box oil already but put in a cheap grade oil which in turn has not improved the gear change between 1st and 2nd by much, i am trying to locate the proper oil Texamatic 7045e but am havig difficulties, i live in ireland and would be grateful for any advice. thanks new owner
1 - 8 of 8 Posts
Suggest you repost your query in the ZT/75 section of forums, lots of knowledgeable diesel owners there
Welcome to the forums
if you cant source the one you want the original MG/ROVER JF403E will do , failing that the land rover fluid is suitable but i dont know the code for that.
FLYER.
Hi Marco I had the same trouble when I was changing my ATF.Motor Factors were prepared to sell me anything,and when I found a place that could supply the proper ATF,they wanted almost Euro 80 for 5 ltrs.Eventually I got it in Enniskillen from Toppings.They're Land Rover dealers and do the complete range of Rover spares,as they're also X PART.They delivered stuff to me by courier for a small charge.Their No is00442866323476.Ask for George as he's very helpful.The Atf you need is JF 403e,Part no VYK000040.I think I paid about Euro 30 for 5 ltrs.By the way where in Ireland are you?
  • Like
Reactions: 1
Hi,
Try Opie Oils, they will send out to you.
http://www.opieoils.co.uk/
Ian
Unsure if the correct fluid will fix a 1-2 shift fault.
The strange thing is all the other manufacturers who use the Jatco unit recommend a different fluid from each other. ( a different name and part no)
We use fully synthetic LT fluid in our Jatcos and never had a problem.
Billy
1 - 8 of 8 Posts
