Hi all,
Just a quicky....What is the difference between a 'Normal' Audi 1.9 TDi and a 1.9 TDi PD engine??
Many thanks.
Rob
I think it's the injection system. Someone more knowledgable will be able to confirm or otherwise I'm sure.
Quote from http://www.volkswagentdi.com.au/why_diesel/pump_duse.htm
"Volkswagen's Turbocharged Direct Injection (TDI) diesels are at the forefront of today’s diesel revolution thanks to our exclusive Pumpe Düse system.
High Pressure Injection
Pumpe Düse - which means ‘pump injector’ - overcomes the problem of pressure lost through fuel pipes. The injector and pump are integrated into a single Pumpe Düse unit. Each cylinder has its own Pumpe Düse unit mounted in the cylinder head and operated by the camshaft, injecting fuel
directly into the combustion chamber at pressures up to 30,000psi.
These high pressures produce a far more efficient blending of the fuel/air mix, precise control of fuel quantities and injection timings.
Increased Performance & Economy
Benefits of Pumpe Düse include good fuel economy, reduced exhaust emissions, and substantially increased performance with more torque than traditional injection systems. The Pumpe Düse engine is also relatively quiet in operation, with noise levels similar to those of a petrol engine."
