1 - 10 of 10 Posts
Hi everyone.I bought this info off ebay, do we know if all the below is just rubbish?MG ZT 2002 MODEL REMOTE KEY PROGRAMMING Method 1:1. Lock car by using key in lock2. Move out of range and press button on fob for 5 secs.3. Unlock car door with key but do not open door4. Standing near the vehicle, press the dotted button 4 times very quickly, the door should lock5. Then press the unlock button and door should unlock.
Method 2:1. Remove remote battery and press any button on the remote to remove any charge left.2. Standing near the vehicle, re-insert remote battery and quickly press the Unlock button 5 times quickly.3. Remote should now be operational
Method 3:1. System must be disarmed first, turn the ignition on and then off within 3 seconds.1. Open the tailgate and leave it open2. Again, turn the ignition on and then off within 3 seconds.3. If the procedure has been done correctly, the horn will sound briefly and the alarm LED will come on and stay on.4. Press the button of the first plip to be coded, the fob LED will come on, go off and come back on again. If the 3AS unit accepts that plip, the alarm LED will go off briefly and come back on.5. Repeat this last procedure to code another plip, the maximum allowed is two.6. Exit the learning mode by turning the ignition back on.
Method 4:1. With the doors shut and from inside the vehicle.2. Turn ignition to position 1 and back to off within 5 seconds.3. Remove key from ignition and press and hold the unlock button for 15 seconds during this time press the key lock button 3 times within 5 seconds.4. Release both buttons.5. Doors will lock and unlock to show correct programming has occurred.
Method 5:To do this procedure you need to have one working key and one key that needs to be programmed.1) Get in and close all doors.2) Turn on the ignition and turn off quickly. (No more than 5 seconds) to start the process. Next action must take place within 30 seconds.3) Remove the 1st key.4) Hold the key up near your left shoulder (this is so it is closer to the remote receiver antenna.5) Hold down the unlock button and press the lock button 3 times. Release the unlock button and the doors lock which confirms the operation.6) Quickly repeat steps 4 & 5 for key #2 etc.If it does not work, try doing the keys in opposite order. Key 2 then key 1, vs 1 then 2.
Last one:Method 6:Alternate if you do not have a working remote1. Turn key to position 1 five times very quickly2. Remove key3. Hold unlock button then press lock button 3 times, release unlock button.4. If you have another key do the same button pressing within 30 seconds5. Turn on ignition to finalize.
cityrover
Its just a re-sync program that he's sold you. This is in case the fob becomes a little out of sync with the cars ecu, and sometimes causes problems when trying to unlock the car from a distance ect. You cant program a fob without specialist equipment.
1 - 10 of 10 Posts
