Shouldn't be an issue. The Ones on my Coupe are the same handles, but come colour coded from the factory.
Well if you were a gent Si you would open the door for the ladies...LOL.:bgrin:Si said:aslong as the surface is prepped properly and has a proper primer used then it should be fine mate, the only thing i would worry about is scratching off girls with rinigs etc :bigeyes:
i don't need to no more seeing as i am getting wed in october!!!!!!!!!ashy said:Well if you were a gent Si you would open the door for the ladies...LOL.:bgrin:
Oh sad man...kiss goodbye to modding the car then. That usually goes outta the window when she starts putting her foot down.cheungy said:i don't need to no more seeing as i am getting wed in october!!!!!!!!!uch:
Exactly the reason why I haven't done mine. My advice, if you are going to do this, is lots and lots of layers of clear lacquer, and bake them in the oven at the lowest heat (usually 50 deg C) for a couple of hours before refitting.the only thing i would worry about is scratching off girls with rinigs etc
