Any intrest in VIS indicator kits?
13K views 67 replies 19 participants last post by  PaulH2007
Have produced a batch of these for members of theMGZS.co.uk although have enough components to produce a few more wondered if anyone on here would be intrested?
Whats a VIS Indicator??
Basically the VIS motors open at different points in the rev range allowing more air into the engine giving the full power of the engine.
The VIS indicator consists of 4 leds, 2 for each VIS motor that will be fitted to the blank on the dash just to the right/left of the steering wheel. As the actuator in the motors open it feeds a signal back changing the LEDs that light up.
In basic terms it allows you to know when the motors are open and you will be able to tell if they are faulty. As its often a cause of a low powered 180.
They are going to come with Red and Green LEDs. Rather than the blue pictured.
The Kit consists of:
LED indicators that are mounted to the switch blank,
All the Wiring to install
Installation instructions
This kit requires you to splice into the loom for the VIS motors, splicing and soldering onto 5 colourcoded wires that will all be explained in the instructions included.
They will come at a cost of ÂŁ30 inc postage. I would also be greatful if the switch blank the kit replaces can be sent back to me allowing more to be produced. ( I will include a stamped addressed envelope :))
NOTE: This is not a For Sale thread as have not made them yet but if there are members on here intrested as soon as I get some more switch blanks will produce some more.
If people are seriously intrested please let me know, they are a useful bit of kit :)
#4 ·
The VIS motors basically control air flow to the engine, often you can get oil vapours in them which cause havoc to the circuits within them causing them to fail. Which in turn make the 180 sluggish and feel under powered. There are two motors (power/balance) that open and close at various rev ranges. The indicator taps into the signals from them and lights LEDs so you can tell if they are working properly :)
Hope that helps :)
The blanks are either side of the steering wheel on 400/45/zs and some civics that use the same dash, If they have any would be very useful :D
Let me know and I will cover any costs. Wear big pockets and you could loose a few in them :whistle:
#60 ·
Well im prob not the best person to answer as I find the soldering easy.
Just to let those intrested in these, sorry for the delay not had many of the blanks returned so lawrence-zs180 has managed to source some which will hopefully arrive this week, When they do give it 24hrs for the compound to set and then I will have aload ready for dispatch
______________________
burning ps3 games
copying ps3 games
#19 ·
Just to let those intrested in these, sorry for the delay not had many of the blanks returned so lawrence-zs180 has managed to source some which will hopefully arrive this week, When they do give it 24hrs for the compound to set and then I will have aload ready for dispatch :)If people could list their names then I will pm all with payment details
#24 ·
Yer thanks mate although turns out the hydraulics havent died yet its the clutch release bearing thats gone, clutch is only 2months old!!!
Know that feeling not sure what it is about the post office but theres always one!! They turned up today thanks mate a great help :D
Ive spent the day finishing them off, currently waiting for the potting compound to set then going to test them in a mates car tomorrow (due to my dead clutch :() to double check they are all fully functional then will get them in the post soon as :)
Will PM anyone thats expressed intrest with payment details tomorrow after testing :)
PMs have been sent to those that expressed intrest unfortunally I have less kits than people intrested so its a first come first served basis.
Those that have already paid they are parcelled up and will be sent tomorrow :)
Any questions with installation then just ask :)
As for light sequence if the VIS valves are fully working then they will work like this
#31 ·
possible here - was gonna make one my self but never got round to it - id have a problem with my blank though as I have the MGR frost warning kit fitted into that blank :( so Id have to have a think were it could go or send you my blank with the hole in to fit the extra LED`s to
