7T5 said:how cold should the aircon be? mines not icy cold but it is cold a lot of peeps on here say theres is icy cold. whats the best setting to have it on as i think i must be working mine wrong do i pit it on low or hit auto and leave it at 16? do i recurculate or use exterior air?
thx
MM did we really need to know that ? :bgrin2:mmcomputing said:I find the most comfortable setting all year round is 21 degrees Auto, the recirc will activate when necessary. I only change this setting to recirc manually when i FART to prevent heavy particulates from being passed around the cabin. As with all these things you have free choice and plenty of it.
MM
I leave that sort of thing to those that have just been regassed. Beastskandyman said:MM did we really need to know that ? :bgrin2:
i to have my set to 21 degress auto and with the rcirc on.
kandyman said:to much blowing off in this thread
when i set mine to "Lo" it is really cold but dunno if it is icey cold :errx2:
Maybe what we shuld do is set a little test up for us all.
1. get a thermometer
2. set AC on to LO
3. place thermometer on top of centre conceal
4. drive about for 10 mins
5. post back thermometer readings
It's that Kandyman. I blame the parents. :run!: :happy:tanvir said:Err... this thread has taken a strange turn...
My choice also. Use the auto and let it do its work.mmcomputing said:I find the most comfortable setting all year round is 21 degrees Auto, the recirc will activate when necessary. I only change this setting to recirc manually when sitting in traffic to prevent heavy particulates from the vehicle in front being passed directly into the cabin. As with all these things you have free choice and plenty of it.
MM
I think the term "Icy Cold" get a bit to much use on Ebay7T5 said:how cold should the aircon be? mines not icy cold but it is cold a lot of peeps on here say theres is icy cold. whats the best setting to have it on as i think i must be working mine wrong do i pit it on low or hit auto and leave it at 16? do i recurculate or use exterior air?
thx
