Im sick of my air bag light keep coming on changed yellow connector went off a while back on if i remove the fuse would the air bag still work? Seems a bit drastic but its driving me mad.
The basic problem is the design of the connectors. The pins in one half are quite flimsy/floppy and they are made of a different metal from the sockets in the other half. So, apart from being mechanically sensitive, they tend to set up an electrolytic action which causes a non-conductive gunge to form between them. Result is a circuit failure that's so common, MGR thought the best servicing method was to cut the connectors out completely.
TC
According to MGR, these bolts should be renewed once slackened off. Nobody actually does it, but that's the official recommendation.- - - - remove the four seat runner bolts - - - -
