1 - 8 of 8 Posts
Banned
my inside gauge is showing that the outside air temp is -19 i presume the sensor is faulty can anybody give me a part number and a price for this please
thanks
Try disconnecting the battery and reconnecting - if it stays @ -19C I would check the connection - failing that it would look like a new sensor.
When I took the bumper off mine I disconnected the fog-lamps, sensor connector - when I reconnected it was at -19C, a reset via the battery did the trick ... HTH
Mike will probably come up with the part number but from
http://r75.sytes.net/
"If your temperature display is showing -30deg. then there's a good chance there's a problem with the external temperature sensor. It's mounted on the inside of the front bumper low down on the driver's-side just to the inside of the headlight assembly. It has a plug/connector in the lead just back from the sensor. You should be able to access it from below by removing the under-belly panel from the engine bay. A quick check with a multimeter will show if it's open-circuit (a sure sign of a faulty sensor). Typically the symptoms of a faulty sensor are: display at -30deg. and system blowing hot on any setting except 'Lo'."
Didn't you say you were having Aircon problems as well recently?
JTF100160A £11.06
JTF000180 £6.41
Depending on the year and serial number of the car. Prices may be a bit out of date.
Banned
Discussion Starter · #8 · (Edited)
hi
the bumper has been off the car as ive had new fan motor fitted, when i collected the car the temp said -30 but after a few yard drive it went to -19 and stays there, the heater works fine on all settings.
thanks for the part numbers where did you find them? i searched the net for ages and couldnt find anything.
disconnected the battery and it has solved the problem outside temp now showing normal
thx
1 - 8 of 8 Posts
