Hi people,
i had some bits done on my r45 today but im not sure if the mechanic has adjusted the actuator right.... I had wingys decat pipe fitted and the mech set he didnt have to take the actuator off, he just tighted up the bolt 3 times.. Can anyone tell me has he done this right?
the reason i ask is i though i would see a much bigger improvment than whats gained... 30-70 took about 9-10 secs instead of 12 before, but im not sure if this improment has just come from the de cat pipe
Cheers guys
Have you had any mods done on the fuelling side?
You probably won't notice much improvement when just increasing the boost if there's no increase in fuel to match.
On a 45/25, you can't manually adjust the fuelling. A re-map is needed to do that.
Skelo
