I have a 2002 TF135 (Manual Transmission of course). I am about to fit a simple (cheap!) low-coolant warning system, which has a buzzer to provide a low-coolant warning, but no warning light.
I can see that there is an (obviously) unused Gearbox Failure warning light for cars with Steptronic Transmission., see diagram and picture of back of instruments below:
In the picture above, the back of the instrument panel circuit board shows a track running to the warning light I want to use circled in green.
My questions are:
1. Could I connect a wire to the screw in the centre of the green circle above. This wire will become live when low-coolant is detected by the system I am about to fit.
2. Will doing the above cause any problems?
Thanks for any information from those with better knowledge of this panel. Is access to the back possible without removing the whole assembly?
My questions are:
