!!!update!!!abs light coming on need help please for 820 rover vitesse fixed
ok
driving along then suddenly abs light comes on and stays on,if i switch engine off then on it goes out then after about a mile it comes back on, so i tried the join the yellow green to black wire trick to get the code ,code said front right sensor
(4 flashes then 3) so changed the sensor took it for a spin fault seems to have gone but when i check with the yellow green black wire thing it comes up with the fault code 4.3 does this mean it still has a fault or is it just stored in the memory so it just need's reset ,if it need's reset how can i do this thanks any reply's much apprieciated.
ok
