1 - 1 of 1 Posts
Hi Guys I have a problem with the abs light coming on a few seconds after driving off and then staying on. However after checking for the ABS Fault Codes, there were none, I'm guessing that it's probably a wheel sensor that's at fault, as if I just run the car without moving it, the light doesn't come on. Just thought I would ask on here before I started messing about with it to see what you guys thought the problem could be. Thanks for any help.
1 - 1 of 1 Posts
