I have just suffered from placing too much faith in BBC Weather App, or too much blind optimism: take your pick.
The result was coming out of the Honiton Supermarket to find a heavy rain shower had started. Ran to the TF pushing my trolley full of groceries. Park trolley where it cannot escape downhill, unlock TF and raise hood in double quick time.
Then the REAL problem started: I realised that as usual, I had driven to the supermarket with driver's window fully down, (reduces backdraft, even with my "new" (Second=hand) windstop fitted.
Switched ignition on, raised window with door still open (did not want to sit on a wet seat, + shopping getting wet and still had to be put-away in boot.) You have guessed by now that the window went up beyond normal top position, and would not go down.
No help in my usual "First Resort" of Roger Parker's books, so consulted this site. (Searched "Window Stuck" on F/TF forum)
BIG Thank-you to MGFNorway. His explanation of how to cure this problem is EXCELLENT! but:
1 correction.
His photo, indicating where the rear access hole for the REAR bolt holding the window to the lift mechanism is wrong, see below.
Correct holes are circled green, the only error in MGFNorway's description is the one I have shown in RED.
I AM IN NO SENSE CRITICSISING THE ORIGINAL POST, IT SAVED ME MASSES OF TIME!
I am posting this quick message just to help anyone else who has the same problem.
Hope MGFNorway still has his F or TF and reads this message.
I was pleasantly surprised to find that the stop attached to the window was (as far as I can see) undamaged, see below:
I have turned it though 180 degrees, as recommended, just to move the wear point.
The window winding mechanism is moving freely, so no collateral damage, so after I have taken the opportunity to lubricate tracks etc. with Lithium grease, reassembly will happen tomorrow. Watching F1 on telly (what a RACE!!!!) and cooking dinner kept me away from completing the job today.
1 correction.
