A little coolant loss
3K views 23 replies 6 participants last post by  warwickswinger
I've had my ZS120+ for a few weeks now, and 2,000 miles or so later I have now experienced a little bit of coolant loss. I last checked it about a week ago and the level was fine (I spotted it today as part of a routine look-see).
I checked the oil around the filler cap, on the dipstick and looked for signs of oil in the expansion tank:
  • Clean dipstick
  • Clean oil filler cap
  • Correct oil level
  • No oil in expansion chamber
  • Temp guage has never moved above just-below the middle of the guage
I did however notice the following things:
  • The oil is a light brown in colour. Is this normal? Forgive me if this sounds a stupid question but I'm more used to diesel cars and motorbikes - this is my first petrol car. The oil in my diesels was always black, as is the oil in my bike after a couple of thousand miles (hardly surprising when they rev to 13,500 rpm lol). I guess I'm just looking for re-assurance that light brown doesn't necessarily mean chocolate milkshake.
  • There's a tiny bit of crustiness around one of the cooling system rubber hoses at the end, although it wasn't wet. Not sure what the component is as I was in a hurry, but I can post a pic up later. It's just behind the rad, a union where a thick rad hose meets a smaller hose.
So, I have a few questions:
  • I've got some ready-mixed coolant for my bike in the boot, it's bluey-green in colour. The coolant already in the car is orange. Can I top up the system with the coolant I have already? The level's about 1cm below the max mark. If not, why not? What are the consequences of doing so?
  • Is it possible I've got a small leak on the rad hose, or is a tiny bit of crustiness normal? It's not too disimilar in appearance to alloy corrosion to be honest, but it is a slightly different colour. I can get a pic later if I'm sounding a bit too vague.
  • Should I be overly concerned about this drop? The car's had a FRDSH up to 36,000 miles. It had 39,000 miles on it when I got it and it now has 41,000 miles on the clock.
  • Where can I get a reasonably cheap UV light to check for coolant leaks (I assume it flouresces)? I'm a bit skint at the mo so cost is a factor :)
I think the greeny blue is the wrong kind of stuff. You want the organic stuff. I'm not sure if they are mixable.
Sounds like you have found the leak to me. Cooling system is hot, so the water evaporates quickly from slight leaks. Maybe have a look with the engine running and warmed up.
Certanly keep an eye on the level. Driving it if it gets too low can very quickly lead to HGF.
#3 · (Edited)
Hence my weekly checks ;)
Thank you very much, I shall have a look with the engine running. I think I've got some orange coolant anyway (Halfords pre-mix) at home in a large canister.
I'll put some photos up when I can (Might be a bit too dark tonight though), so hopefully we can get this diagnosed and sorted before it becomes a proper problem :)
If I have got a small leak on this hose, I'm guessing it's going to be very slight - a 1cm drop over 500 miles or so isn't a vast amount of fluid per second coming out any gaps. Is there anything I can do to maybe show up the leak; a bit of newspaper around it or something else which will react visibly to getting wet? Or is that what the UV light's for? :rolleyes: :) I've not used UV for diagnostics before so I don't know how obvious the effect I'm looking for is.
Brown oil is a bad thing!
It shows that it is contaminated with coolant so this may explain the loss you mentioned. Sound very much like the early signs of a head gasket problem I'm afraid. :(
The only other possibility is that it has had a previous failure and has not been flushed properly. Has the oil been this colour ever since you had it? If so, it might be worth changing the oil and filter and monitoring the condition.
I did think brown was a little 'off colour' I must admit.
I've been planning to change the oil anyway; the oil was changed at the last service 5,000 miles ago and Haynes reckons it's due a change every 7,500.
Here's a couple of pics:
My oil filler cap
The suspected leak
Another shot of the same with a different camera settings.
The car's still under warranty, but if it *is* HGF and I need to sort it, I might still take it to an MGR specialist or have a crack myself & fit the LR gasket. Don't want to get ahead of myself though.
What do more learned folk make of the pics?
I've got some OAT antifreeze (it's pink) at home, so I've mixed some up 1 part anti freeze to 2 parts water. It looks a bit more red than what's in the header tank, but will this be okay to top it up with?
Ah cool. I assume it's okay to top up the coolant with my 1 part OAT a/f with 2 parts water mix?
When I wiped the dipstick on a cloth yesterday before dunking it, it looked a little brown to me. It didn't look like milkshake, just a lot lighter than I was expecting. I'll get another pic of what I'm on about today.
Many thanks,
Chris
#12 · (Edited)
Thank you :)
I topped it up and it took about 500 ml to bring back up to the max. mark. I'm surprised how small the tank is - I was reading the Haynes manual and the entire cooling system from dry takes about 4.5 litres. From observation I'd say the header tank takes about 750ml from empty to max? I'd've expected it to hold more than that.
I was reading another thread about the header tank filler cap - I'm sure I did it up a little tighter this morning than the last time I checked it so maybe I was losing a little through that. I'd imagine what's coming in from the return pipe is pretty hot, and if the seal wasn't bang-on it could have been evaporating out? I'll keep an eye on the oil and coolant level and see how it goes in any case.
When I get a chance I'll give the cooling system a more thorough look-over for leaks, but I want the engine cold so I can poke and prod it without burning myself.
Anyone got any comments on the deposit I photographed?
Cheers :)
#15 ·
Replace the coolant tank cap, tighten all of the jubilee clips and replace all of those horrible crimp/spring hose clamps with jubilee types.
The deposits around the hoses is where coolant has weeped, the water content evaporates leaving behind the crystallised chemicals from the coolant.
Got your PM, is that 400 a diesel??
#20 · (Edited)
You know me mate... if I would, I could :D
I have a 1st floor flat where I am now, and it's lease-hold so I think I might have difficulties knocking out a wall and putting a ramp or a lift in :D In the old place, even if I could have got the car through the door there wasn't quite enough room. Not sure why :rolleyes:
One day, there will be room for all (maybe even the g/f once the car and bike have a home ;))
I'll let you know about the cap - I'll keep an eye on the level and replace those clips for the time being. Visually there didn't seem to be anything wrong with the one I've got, and seeing that evidence of weeping makes me want to sort the obvious stuff first :) If I'm down your way soon I might have one off you anyway though :)
Presumably if I remove a clip with the intention of replacing it, coolant is going to leak and I'll have to re-bleed the system? If so, I might look at the cost of replacing the hoses and tie it in with a coolant and oil change, do the whole lot at the same time.
Nah, it was a 600 :) I don't have that bike any more. I've got one of these now:
Sadly that Bandit is no more - hit a patch of diesel, front wheel slipped, I shut the throttle and wallop, on the deck :)
Still, there's one less MkIV escort estate on the roads as a result, so it's not all bad ;)
As for the g/f, I think I have possibly THE most understanding lady on the planet... All I got was a 'tut' when I stripped the brake calipers in the kitchen sink :D
