827 coolant leak, help!
884 Views 6 Replies 4 Participants Last post by  RAY-827
I have an 827 sterling which is leaking coolant from above the pump?
there seems to be a purpose built hole for the leak? the pump does not have any play and spins, could it be seized inside or is there a blockage?
Welcome to the forums!
Sounds to me like your waterpump is shot mate - new pump time i'm afraid!
my 827 vitty's done the same for 5 years. I belive it's a common fault but i would'nt rush out to get it fixed. Seems to stop leaking during the summer though!!...You 'll never need to do a coolant change...If that makes you feel any better!!!
The vee between the two cylinder banks..... \/ see it?
