rover_75
I have an annoying buzz eminating from air vents in wooden dash. It only 'appears' when engine is labouring (up hill). Any suggested cure?
Rover 75 TDI '05
hi mate,
i had the same problem which turned out to be a loose vent.i had a tiny hairline crack on the airvent surround which meant it had come slightly loose.i just pulled it out a bit and stuck some punture repair kit glue(the rubber stuff) behind it and it worked.u may not have a crack in it but it may be loose.it might expain why it only happens when the car is labouring due to the car vibrating.
the next time it happens try pushing the vents that the noise is comming from and see if it stops,if it does then theres ya problem...hope this helps mate:O
