I wonder if anyone can help. I had the clutch replaced last May. The new one is now playing up. The symptoms are not being able to select any gear while the engine is running. Gear changes are fine with the ignition off.
I can get it towed back to the garage next week but if it's straightforward I'd rather sort it out myself.
I read somewhere that it's probably down to low hydraulic level in the master cylinder, which I've located on the clutch pedal. If the level gets low it can draw air in. If this is the case I'll need to top it up and bleed the system, but I've no idea where the bleed nipple is.
Can anyone please help?
Keith
