Just noticed that when I operate the HRW switch the light illuminates , but does'nt stay on when released. Thought it might be some sort of relay at fault, but I can't find it ...anybody any ideas ? The window is definately drawing power because when you hold the switch in the revs drop. If it's the switch I wonder whether it's interchangeable with the cruise control switch.
Not really sure on how they work, but the light on mine does not illuminate, but the heater works as you can see it de-misting in lines.
Your heated rear window switch seems to have the same problem as my cruise control switch, i.e it works OK but there is no light to tell whether it's on or off. To get my rear window heater to work I would physically have to hold the switch in, which I'm not keen on doing in case something starts burning !
