Hi Dave,
I have had this problem since I bought the car (about 3 weeks ago). Apart from being annoying, it's costing me a fortune in petrol!
Symptoms:
1. Car is difficult to start and sometimes requires 3 or 4 attempts. Starter motor turns over (so battery is OK) but sometimes disengages and the motor just spins!
2. The car nearly always starts first time if I put my foot down on the throttle about an inch or so.
3. Fuel consumption is only 18-19 mpg around town (I used to get around 25mpg in my other Ti)
The car has been down to SMC Rover in Slough and here were there findings:
1. Carried out testbook - no fault codes
2. Reset throttle cable (was too tight)
3. Checked and reset base idle ("was 62 steps now 32 steps")
4. Carried out MAP sensor test - reading was too high
The car is still pretty much the same. So, I guess that the MAP reading too high is the main clue here...
What can cause this? Apart from the low mpg, once started the car runs fine.
Rover have suggested:
1. Timing (Cams) could be out.
2. Faulty MAP sensor.
3. Faulty ECU
I guess low mpg means it is running too rich. Any advice appreciated on where to start (BTW I have changed the plugs and leads).
Could I have two seperate problems ??
Many thanks Dave
Wayne
Symptoms:
3. Faulty ECU
Many thanks Dave
Wayne
