1 - 2 of 2 Posts
My bro is having problems with his Ti clutch. It needs a replacement. he is incredible at spannering, taught himself but he could do with a roughidea of how to change it.
Can anyone help?
cheers guys
Mark
its actually quite an easy job.
remove most of the things on top of the gearbox to access the bolts, remove the starter-motor. under the car you need to remove the drive-shafts, empty the gearbox oil before you pop them out ;)
and then just remove some bars here and there, and if i remember correct one of the engine mounts. just put a "jack"(don't know the english word, lift?) under the engine to be able to raise and lower it as needed.
but if your brother is familiar with cars, he would know what to do next :)
also, there are rover 620ti's workshop manuals laying around on the forums. rovertech.net is one of them..
hope this helps alittle atleast :)
1 - 2 of 2 Posts
