45 abs coming on when driving
1.2K views 8 replies 6 participants last post by  runfatboyrun
Hi all just got a 2001 45 to replace my 600 and love it but while driving and not brakeing the abs pump can be heard cutting in sometimes and also sometimes when braking normal comming up to a junction you can feel it on pedal . Abs light comes on when starting engine but goes out after start up so that seems ok , can anyone help please ?
The bit that worries me is that he can hear the ABS pump running when not braking. Don't think reluctor rings would cause that???
With mine it just ticked once per revolution of the wheel, and I heard it from about 5 mph up to 25 mph then it stopped.
I did hear it when not braking.
If you have more than one ring split or otherwise damaged, (ie tooth missing) then it would not surprise me if the sound is different.
However, 'runfatboyrun', if you have not found a split/damaged ring then the cause of the ABS pump running could be something else and needs investigating.
