hi my gsi failed the mot on emissions could this be the lambda how do you test them. also i blew down the vacume pipe down to the ecu and was ok until i connected it to the ecu then became blocked should this happen what eles could cause high emissions air filter ect
The vacuum pipe action is ok, did you check the cam timing? You need a voltmeter to check the oxy sensor, although from memory I've had a couple of 2.0ltrs which have had a build up of carbon in the exhaust manifold keeping the gas from the sensor.
420gsi
cam timing is spot on i will blast the manifold out. i have four wires on the oxy sensor two white one black one grey which wires do i test thanks
