Hello there,
I have been having a problem on and off with my 1999 Rover 420 GSDi for a month or so now. The problem is that every now and then the Engine Management / Fault light comes on and the vehicle has pretty much no power.
It started about a month ago when it was first fired up in the morning, it would come on and go off quite a few times on my way to work, but by the time I get to the motorway (3 miles / about 10 minutes) it would be off and fine.
After a good search through the posts on this site I came to the conclusion that it could well be the MAF sensor. So I took this out, it was a bit oily so I gave it a squirt with some carb cleaner. I thought this had sorted it until this morning when it happened again, but this time it came on and off a few times but didn't sort itself out by the time I was on the M5 and it would only do about 75mph.
It has occured to me that I may not have actually done any good in the first place when I cleaned the sensor. It happened to coincide with the time the weather improved a bit and it got warmer. However this morning it is bloody cold and its bucketing down.
Has anyone got any ideas on this one??
Thanks in advance.
Joe
Thanks in advance.
Joe
