i took the car apart last night to fit new glow plugs,including taking the fuel pump off,when i put it all back together the car still wouldn't start !!
it started in the end ,by me spraying carb cleaner into the inlet and my wife turning the car over,i had checked and checked the timing,and that all the connections were all back on,the only 2 connectors i took off were the one from number one injector,and the pump connector,i put new leek off pipe on while i was at it and a new fuel filter,i pumped the bulb until i got fuel coming out of the banjo on the infeed to the pump,now i'm just wondering if it will start in the morning ???
Have you checked that the glow plugs are getting voltage? It isn't unknown for the relay to fail leading to poor cold starting.
yes mate , i checked the relay before i decided to under go the pain in the behind glow plug change,and to top it off i tested all the old glow plugs to find that that all glowed up, lol
