1 - 2 of 2 Posts
mg_zr
got problems with my 200turbo engine?? the pipes are all to **** and when i had a look at my m8s turbo to check he had a pipe off that we dont know where it goes?? so has anyone got any diagrams for the air pipes? ive got the purge going to inlet manifold,inlet to ecu,dump valve to under throttle (rear ),actuator to under throttle(front) and a spare pipe thats t pieced into the actuator pipe? i have a bleed valve but aint plummed it in yet? car running but wont rev over 4000rpm and boost no higher than 5psi. anyone??
mg_zr
Discussion Starter · #2 ·
fcuk it im gonna plum bleed valve into actuator pipe and completly remove the unwanted pipe so i now only have one pipe from actuator going to bleed valve then continuing on to underneath throttle(front).
1 - 2 of 2 Posts
