went today to lock the drivers door.central locking did not work.if you manaully push door drivers lever,the central locking also did not work.nor did the immobiser light come on using the key.but if i lock passenger door with key,the alarm light comes on.shed some light please.
Had a similar prob with my 414.Central locking worked but the immobiliser light was on all the time.It turned out to be the multi-plug behind the drivers door had come adrift.The ecu didnt know if the doors were open or shut.Also check the central locking fuse in the engine bay.
214 central locking
ok .found the problem was dowen to a fautly master door motor.after moving it up and down,started working normal,will replace before adding car alarm 2 wire motor.thanks
