1 - 9 of 9 Posts
I recently bought a 99 211 for my son (when he finally passes his test).
There is a problem with the central locking. When the remote is pressed, the alarm is activated but the door locks don't operate. Neither do the door locks operate from the key. When the remote is pressed, a slight "click" can be heard somewhere behind the steering wheel.
Any help would be appreciated.
Many Thanks
Graham
mg_zr
I don't think the model you're got has Central Locking.... so rather than not working, it's not fitted.
Mmmm....Rover..
I doubt that your car has central locking...sorry.
The faint clicking you hear are the relays in the alarm ecu, it's behind the dash...near the steering column.
rover_100
as Phil writes...
are you saying you can't lock/unlock at all, or that you need to do each door separately with the key ?
The doors all lock and unlock by key. I thought having key fobs indicated that an alarm and central locking were present. Am I wrong?
Is there any difinitive way I can check if central locking is fitted?
Thanks to all.
Graham
cityrover
i know this is obvious really, but have you checked all the fuses? (including the engine bay fuses)
no, mine has the fob for the imobilaiser, but does not have central locking fitted, was an extra on the base model cars
mg_zr
Was even an extra on the ZR...
All cars have the fob, for the immobilizor... but the 211 didn't have Central Locking......
If the car has central locking, there will be no lock on the passenger door handle!
1 - 9 of 9 Posts
