mg_zs
Hi when the phone is connected to the zs via bluetooth the contac list has a few of the contacts duplicated and with incorrect numbers, on the phone they are all ok I have deleted the connection a few times on the zs and the phone but the problem is still there I wonder if any one else has had this problem I would appreciate any help or suggestions many thanks.
John m1efp
I had this problem a long way back so from memory it was something to do with how contacts are stored either on SIM or phone if some are stored on both you get the duplicate contacts listed.
Not sure if this is still the way contacts work but might give you something to look into.
If you go into contacts pick one you know is duplicated then click edit it should tell you where the contact is stored.
mg_zs
Ok Chis thanks for your helpful reply I will look to see where the contacts are stored many thanks.
John m1efp
