Hi everybody! Can anybody help me?
I have Rover 200 SDi, 99
At the some time have a problem with alarm. All the day remote contol can lock and unlock doors/imobiliser if I drive. But at the morning (or more then 5 hours after using) remote contol can't unlock doors/imobiliser. I can unlock doors by key, but can't imobiliser. If I reconnect the battery it start work again.
What problems? Where is the alarm?
On remote - VALEO, not infrared.
Thanks in advance
Anybody are there?
Did anybody saw the alarm? did not run past?
You'll be waiting for a long time for a reply mate, NOBODY likes to help out in regards to these type of problems.
Whether it is through lack of knowledge, or unwillingness to help in these matters, i am not sure.
I had a alarm problem, which i posted about recently. None of the usual respondants answered the question, i had one reply which was unfortunately not correct. Full marks to the person who tried to help me tho :broon:
It might just be the battery in the fob playing up, might be worth a try of replacing the battery in the key fob.
Skelo
The battery is the normal culprit.
Does the car start ok once you reconnected the battery?
Check to make sure that all the earth's are ok. The entire elctrical system can play havok if not earthed properyly. I don't know where they all are but someone else should.
Hope that helps.
the earth
I think so. But where is the alarm?
Hi!
It is not the battery in the key fob. But if I replace it (old, not new) it start work too.
But it last time I'dreplased some for rsult :-(
