mg_zr
I have a 2003 105 mg zr(3 door), I have a problem with my doors. I have to slam them hard to close them. If I try to close the doors normally they dont close.:O
try taking the seatbelt out from the bottom.. you should be able to adjust the position of the door catch with a screwdriver.
Yes just a couple of screws need loosening on the striker that is attached to the door frame and you can adjust it. This will likely be your problem.
