Hello all,
Our Rover 45 TD has developed an annoying fault which I'm scratching my head about. I'm posting here to see if it's a knackered starter and if so whether it's user-servicable or if replacement is the only option.
Basically twice during the very cold weather I couldn't get it started - on turning the key it behaved exactly as you'd expect, except the starter motor wouldn't move or make any sound as if trying to turn the engine over.
The first time it fixed itself after I pushed the car into a parking space in a car park, the second time I gently tapped the starter motor with a socket wrench and got it started.
The battery is fine, as is the keyfob and locking/unlocking didn't make a difference. There were no warning lights and all fuses are intact.
The first time it happened I tried to find out where the starter relay is so that I could listen to see if it was clicking but the noisy environment I was in meant I couldn't track it down so I don't know.
The car has 101k on it and recently had a new clutch and clutch bydraulics but I don't necessarily think that the clutch and this problem are linked. It's used every day and does about 15k a year and when the starter works it appears normal with no odd sounds or anything like that.
I've got a multimeter in the car now so if it happens again I can see if there's a voltage getting to the starter when my other half tries to crank it - at the moment I don't know if it's an electrical fault or a starter fault.
Any ideas? - Cheers!!!
