temp gauge goes to red in town
gets mega hot
ok on a run
fan not cutting in
wheres fan sensor,,also i see two fans,2 sensors??
can i bridge it somwhere till i get a sensor??
ECU controls the fan.
Disconnect the two pin temp sensor.
Turn the ignition on
Fans should run on low speed.
If they don't then need to fix the fuse/relay/fans/wiring.
if you have air con, worth turning that on when it over heats to get both rad fans working on full power.
I guess you checked the coolant level? Any coolant leaks?
