A bit of background first. A month ago, the engine overheated due to coolant loss...apparently, no evidence of HGF, no mayo, compression ok. Water pump and rad changed. Engine was still reluctant to start...ALMOST firing immediately, and then eventually firing after 5 or 6 seconds of turning over.
A week later, the head gasket DID fail and was replaced. The guy that skimmed the head said that it had at sometime become VERY hot and the advice was to sell the car ASAP.
Is the starting problem (which is still the same) due to a warped/damaged cylinder head or something else?
HT leads, plugs, distributor cap, coolant sensor (the brown one at the front) are all new. Despite the advice I can't afford to replace it at the moment
Hope this is understandable... i'm a 'non-expert'
TIA
TIA
