Hi, if you are on a budget get an SU electric pump from another Mini (or a Morris Minor) if money is no object a Facet pump & a filter king regulator will do a superb job.
You should always wire through an 'inertia' switch (Ford Sierras had these fitted as standard in the spare wheel well) then in the event of an accident, power to the pump will be cut preventing possibilities of a fuel spill.
