First of all, nothing cant be done
Second of all - Which engine are you talking about, the Rover 2.5 KV6?
Challlenges will be (briefly)
- Weight issues, and destroying the balance of the car (K-Series is a light alloy engine, KV6 is a lump of pig iron)
- Space, there has only been one KV6 conversion I remember in vague memory, and it involved cutting into the boot and/or tank area.
- Custom engine mounts (obviously). I dont think it has a single one in common with the K-Series
- Custom driveshaft. For the sake of sanity most conversions use the matching gearbox for the engine (Honda conversions end up with a 6-speen MG
), but its mating it to the car that requires a custom (=expensive) part.
- ECU. Expect an emerald / similar at the very least.
If you are looking at going an engine conversion (and why not
) I would suggest you strongly consider the Honda VTEC (Type-R) route. A couple have been done with plenty of success. Its not a plug n play kit by any means, but there will be some exeperience / assistance kicking about.
Good Luck
